Bob_Vaughn
Aug 31, 2015Explorer
Disc Brake Actuator
I am looking at having disc brakes installed on my 5th wheel. Is there a brake actuator that I should stay away from? Or is one better than the rest?
aruba5er wrote:
To compare actuators, one must have used 2 or more. I can't imagine that many have done that. I have the Titan and it's just fine. No need to compare. The kit was supplied with it. And as far as brake pads, even the worst will be a vast improvement over the cheap c**p drum brakes they pass off as brakes.
Randu wrote:
Ive had 2 different trailers with Disc brakes since 2005 and they both came from the factory with This actuator. No issues at all. Randu
I had that on our 07.5 MS and I "think" the same on the new 16 MS. No problems, no delays.
Randu, on a side note I replaced the Kodiak pads on the new MS with the NAPA Best SemiMetallic pads like I did on the 07.5. Was not satisfied with the factory installed pads. For sure better braking.
