- FizzExplorer
obgraham wrote:
I think this difference in recycling approach between Canada and the US is a bit more complicated.
I've seen studies showing that much of the recycling is simply not cost effective, and is more of a sociopolitical statement than one of economics. That's why recycle programs in the US are falling into disfavor -- communities just don't want to pay for them.
I'd be interested in finding out specifically what happens to that steel propane can placed in the recycle bin in Canada. Where does it end up, and what is the cost to send it there?
That's not to say there is no value in recycling. Aluminum cans, cardboard, and newsprint (back when there were newspapers!) are easily recycled into more product.
It's not about cost anymore.
It's about cleaning up your back yard.
You have to start somewhere. - westendExplorerThey have a sign on the local recycle/haz waste drop-off site: "Reduce, reuse, recycle". Any one of those is appropriate for propane cylinders. In my area, putting an empty in the household trash or the recycling could mean trouble.
FWIW, I'm real happy with our local recycling center. They have a separate room with shelves full of paint, cleaners, solvents, etc. I haven't bought any varnish or stain in years. Take as much as you want and no charge! - Jayco-noslideExplorerGuess I never thought about recyling them but I will now.
- bobsallyhExplorer IIThere is a recycling bin at Bakers Hole Forest Service Campground just north on RT. 191 out of West Yellowstone, MT. That wire mesh basket seems to fill up fast. It is the only place I have seen a recycling bin for them. When I used them many years ago, I'd remove the Schrader valve on the can and toss it in the trash.
- K3WEExplorer
SidecarFlip wrote:
Halmfamily wrote:
Use them for target practice.
So do I actually. Then it's off to the scrap barrel and then to the scrap yard eventually.
^^^This^^^
To be honest, I have NOT done this- but now see the beauty.
Throwing a 'sealed-propane-containing' container in the recycling bin seems like a slightly bad practice...mini explosion. Maybe not the end of the world, but...
While the 'not-supposed-to-refill' crowd argues with the 'but that's what I do' bunch and the 'it's so cheap anyway' bunch...
Shoot them...(that vents them), and then recycle them, save the planet, practice your marksmanship and sleep guilt free that you are not adding hazardous waste to the landfill.
:-) - hotpepperkidExplorer
Yep - obgrahamExplorerI think this difference in recycling approach between Canada and the US is a bit more complicated.
That's not to say there is no value in recycling. Aluminum cans, cardboard, and newsprint (back when there were newspapers!) are easily recycled into more product. - Oops - operator error
SoundGuy wrote:
So in the meantime until we catch up what am I supposed to do, just leave em laying around in the garage and go buy new ones?troubledwaters wrote:
Seriously - You refill them and then you don't have people disposing of a few hundred thousand steel containers in a landfill every year.
That's a regulatory issue that can easily be solved, just as it has been here in Canada. Time to catch up.
And then, I should take the old cylinders, put them in my car, drive to the recycling place, which then heats the steel up a few thousand degrees and melts it into sheets of steel, which are loaded on a truck then transported to another plant, which heats the steel again and stamps it into a cylinder, then fills the cylinder with gas, puts the cylinder in a truck and ships it to a store, you go to the store in your car again and buy a new one.
I think I'll just recycle the ones I got just myself like I been doing.- SoundGuyExplorer
That's a regulatory issue that can easily be solved, just as it has been here in Canada. Time to catch up. :W
Looking for advice before your next adventure? Look no further.25,171 PostsLatest Activity: Oct 14, 2025
