transamz9
Aug 02, 2013Explorer
Grit dog wrote:
14 mpg towing doubles, 28' camper and a 4000 lb boat behind that?
I've heard it all now! Dude that truck is worth a fortune with the kind of mpgs it gets. What do you get empty? Must have one of those 30 mpg Duramaxes!!
I can get that with my Cummins and running 60 and I'm pulling more load than he is. I don't see the problem with his numbers.
OP your brakes were just dragging not locked because if they were locked you would definitely know it. You had problems before this problem. I would pull the drums and inspect for heat damage. If it were me I would just replace the backing plates. You can buy them already loaded with all the hardware ready to install. Check the drums for cracks.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
