BurbMan
Mar 17, 2015Explorer III
K3WE wrote:
I am constantly amazed at folks who are so cocked and primed to blurt out "follow directions" that they totally miss it when someone's asking something a bit unique.
Yes, it gets old. However, if you had read the Installation Instructions posted on Amazon, you may have noted the following:
Note: The Cycloneâ„¢ RV Holding Tank Vent was engineered to fit the majority of RV holding tank vent pipes (1-1/2" PVE). PVC and ABS adapters are available at local plumbing and hardware stores to fit other pipe sizes.
The OD of 1-1/2" PVE and PVC are both 1.90", so use the appropriate fittings to change the vent pipe diameter to 1-1/2" on whatever it is you are venting.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
