shades9323's avatar
shades9323
Do I need a WD Hitch
Hi all,
Looking at new travel trailers and wonder if I need a WD hitch? I have been pulling a little Fun Finder 139 without.
We are looking at trailers in the 21-24 total length (including tongue) range and with GVWR in the 5000 lb range.
TV is a 2014 Ram 1500 CrewCab 6'5" bed, 8speed, 3.92 gears, tow package, 10500 towing capacity.
Should I go with a WD hitch?
  • mkirsch wrote:
    You'll probably need one based on the ratings of your truck's receiver. At 5000lbs, the tongue weight darned well better be over 500lbs, and the receivers on most 1500 series pickups are only rated to 500lbs without a WD hitch.
    The trailer will probably weigh between 6000 and 6500lbs loaded and ready to camp, with a tongue weight of 700 to 750lbs. That's WD territory for a 1500 series pickup.
    Get one with built in sway control. It's good insurance against unknown sources of sway, and really helps with the push-pull from large vehicles passing by.
    The loaded weight will be around 5000 lbs. Perhaps I used GVWR incorrectly?
  • You are about to get a lot of opinions both ways. But the truth is that the answer isn't a matter of opinion from afar AND that it depends entirely on factors not so far discussed.
  • You'll probably need one based on the ratings of your truck's receiver. At 5000lbs, the tongue weight darned well better be over 500lbs, and the receivers on most 1500 series pickups are only rated to 500lbs without a WD hitch.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
