- colliehaulerExplorer IIIDon't it give you the warm fuzzies knowing you share the road with him.
- eDUBzExplorerIf hes not over tongue weight he should be ok, not an issue to be concerned about.
- wnjjExplorer IIWow! That is dangerous. The clevis isn't threaded all the way closed and could loosen and fall off! ;)
- darsbenExplorer II
mdcamping wrote:
Defiantly not safe, needs to push the cotter pin in all the way! :B :B
Mike
inadvertent perfect answer - romoreExplorer IISo I sez to the cop " Them stinkin chains is hooked up. What more do y'all want?"
- TucsonJimExplorer IIOh wait! I see the problem now. His catalytic converter's gonna catch the weeds on fire.
tpi wrote:
Not only grossly inadequate method of securing the chain, but also increases the chances of the cotter pin pulling out.
Now I get it. I don't think any of had seen that until you pointed it out! Thanks. :R - AmericalVetteExplorer
You think? :B - tpiExplorerNot only grossly inadequate method of securing the chain, but also increases the chances of the cotter pin pulling out.
- Gene_GinnyExplorerWell, duh, you are only allowed one safety chain per cotter pin. :S
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
