Road_Phantom's avatar
Road_Phantom
Explorer II
Oct 22, 2016
Do RV tires deteriorate when sitting on dealer lots.
I bought a four year old used 5th wheel and had a blowout on my first run. Suspecting that it might be lot rot in the tires, I changed the whole set even though the treads looked new on them. The entire tread on the blowout tire separated from the sidewall and took out the trailer fender. It's my belief that when an RV is sitting in a lot for a year or more in one spot, all that weight on one small portion of the tires undermines the inner core. Watchatink?
  • Just cause the rig is 4 years old does not mean the tires were only 4 years old. What is the DOT code on the tires?
    The tires could be a year or two older than the rig.
    The tires deteriorate anytime they are exposed to the sun unused for long periods of tie
  • Rubber tires start to deteriorate as soon as they come out of the press/mold. How they are stored, cleaned, and otherwise maintained effects how long it takes to become a failure. Just sitting on the ground for four years is a bad thing to do.
  • Cheap Chinese ST tires do that all the time. New,,old makes little difference. Tire quality is what its all about.
    Perhaps. Also constant sun exposure.
    Simply not driving causes tires to get 'brittle'.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 09, 2026
