troubledwaters
Apr 09, 2018Nomad
Rangerman40 wrote:I have run my schwintek slide part way out (or part way in) many times. When I run it back in/out I hold the button for 3 seconds as recommended by the manufacturer. I have never had a problem with it getting out of time. I don't think running the slide part way out now and then is going to cause a problem. Running it in and out all the way without holding the button after the stop is more likely to cause a problem, and probably the way a lot of people are doing it.ScottG wrote:nickthehunter wrote:
Push the button, put the slide out 2 feet, do whatever you needed to do, push the button again.
Exactly.
Our last two TT's required me to put the slide out a foot or two to use the kitchen area.
Holding my finger on the button for 10 seconds is no big deal.
So having a slide in the way of using it at stops makes no difference to us and we are nothing but happy with our floor plan.
Unless you have a Schwintek slide in which case you'll be hating life when it gets out of time and your slide gets stuck two feet out.
Looking for advice before your next adventure? Look no further.25,197 PostsLatest Activity: May 21, 2026
