6_7_tow_rig's avatar
6_7_tow_rig
does a dehumidifier help ac
We are going to Ft Wilderness the first week of September so I am sure its going to be hot as blazes. Our trailer is pretty long and only has one 15k btu AC unit. Does anyone think if I took our dehumidifier from home it would help the AC cool better by removing the moisture? Im hoping we get a shady spot to help but am just looking for any ideas that will help. We will probably be gone during the hottest hours of the day but I dont want to come back after a day in the heat to sit in a sauna. I was thinking it might help with the moisture levels due to pop up thunderstorms
  • Your A/C unit is just a big de-humidifier that exhausts the heat outside!
  • I had a 35' Fw with one A/C and camped all over Fl.. You best bet is to park with afternoon shade and get a couple of small fans and run them all day to circulate the air. That should keep it bearable.
  • BuckBarker wrote:
    Those portable dehumidifiers put out a ton of heat. Things will be worse.
    Never thought of that. Good point
  • Those portable dehumidifiers put out a ton of heat. Things will be worse.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: May 03, 2023
