goducks10
Apr 17, 2017Explorer
IBcarguy wrote:
I use Andersen Ultimate hitch, stock pin box. New 36' 5th wheel about 12k lbs loaded. It chucks a lot over bumps and dips.
I had a B&W before I got an Andersen. I had chucking on rougher roads and even some mildly rough roads. I installed a MoRyde with the B&W and it removed most but not all chucking. This last year I bought an Andersen. I didn't get it thinking it would help remove more chucking. I got it because it's only 50lbs and is way easier to remove when needed and I can hang it on the wall in the garage. I have to leave the B&W on the floor, which is a PITA to lift back up into the truck.
Anyway I have the same exact chucking when using both hitches.
I guaranty that the MoRyde won't eliminate ALL your chucking. Even MR says it won't eliminate all. I only get real bad chucking on the rougher roads.
If you're concerned about what hitch to use as far as liability the call Andersen and get their opinion.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
