- N-TroubleExplorerI use a Demco Glide Ride with my Andersen. I was going to go MorRyde but wasnt sure about the long term affects on the rubber since the Andersen coupler moves the pin weight out several inches on the pinbox.
- n7bsnExplorer
IBcarguy wrote:
Did you install the 5th AirBorne to correct a "chucking" condition? If so, did it smooth out your ride? It depends on who you ask, but some manufacturers do not recommend using a air bag or rubber pin box with a Andersen Hitch. I don't get it. Many of them consider a AU hitch as a gooseneck adapter, which it is NOT. The AU hitch is NOT A GOOSENECK. It simply adapts the pin with a ball at the pin box. I don't see why a MORryde or Demco, or TrailAir wouldn't work any differently than with a regular 5th wheel hitch.
I got tired of the effort to take a 300 lb hitch in and out.
The Andersen is easy - goducks10ExplorerScroll down and watch the video with the 5th wheel in the picture.
https://www.andersenhitches.com/Catalog/ultimate-5th-wheel-connection.aspx - IBcarguyExplorerDid you install the 5th AirBorne to correct a "chucking" condition? If so, did it smooth out your ride? It depends on who you ask, but some manufacturers do not recommend using a air bag or rubber pin box with a Andersen Hitch. I don't get it. Many of them consider a AU hitch as a gooseneck adapter, which it is NOT. The AU hitch is NOT A GOOSENECK. It simply adapts the pin with a ball at the pin box. I don't see why a MORryde or Demco, or TrailAir wouldn't work any differently than with a regular 5th wheel hitch.
- n7bsnExplorer5th AirBorne by Reese (NOT 5th AirBorne Sidewinder)
Looking for advice before your next adventure? Look no further.25,167 PostsLatest Activity: Oct 05, 2025
