oughtsix's avatar
oughtsix
Does my 2006 Duramax need a brake controller?
I am going to pick up our new to us 2006 Coachmen Captive 26ex tomorrow. This will be my first travel trailer. Do I need a brake controller in my 2006 Crew cab long bed Duramax? My Duramax already has the round 7 contact plug on the back of it.
Are brake controllers an added convenience for controlling and adjusting the braking force applied by the trailer brakes? Or are brake controllers a necessity to make the trailer brakes actuate at all? If brake controllers are a necessity does my Duramax already have one built in? (I have towed a large equipment trailer with my Duramax before and the trailer brakes worked properly.)
  • Say looks like you got it going don't worry about some of these guys on the forum they are old curmudgeons and my bet is they don't remember when they were just starting out . Age will do that too you. Trust me I know. So your getting your stuff together and you should have a grand time. Install the controller you'll be ready to go.
    Not so fast!-------This curmudgeon suggests that there may be a fuse to install in the under the hood fuse box so that the brake controller will actually send the current to the trailer brakes. :)
    Well if there is I am sure he will figure that out. Shoot he already figured out he needed a controller I am sure he will figure out the controler is not working and why. :-)
  • :) I am actually a pretty light hearted kind of guy... I didn't take any offense about not knowing if I have a brake controller... well not too much at least! ;) I meant my response to be light hearted... I probably should have included a wink ;)
    Manual doesn't mention a fuse... but I will double check!
  • I had to put a fuse in my truck when I started towing the trailer, but I think that was for the 12V charge line. As I recall the prodigy instructions were pretty good and will tell you if you need to add a fuse for the brake controller.
  • I think the fuse for the controller will be in the fuse panel that he will attach the pigtail into. There are two wires by the master cylinder that must be connected to the under hood fuse box that will supply 12 volts to the trailer. I think the information on this connection is in the owners manual. Also in the Prod. 3 controller information. jerry
  • First brake controller I had to install I had a stiff neck for two days from laying on my back under the dash trying to trace wires and hookup everything up. Second time around was on my 2006 Chevy, purchased new. It had the factory pigtail in the glovebox. Made the job 10 minutes; 5 to mount the prodigy and plug it in, and 5 to install the fuse and make sure everything worked.
    2007.5 is the first year GM installed factory controllers.
  • Go to etrailer.com, put in your vehicle info and look at the description page for the P3 controller. There should be a video that goes over exactly how to hook up the controller including the under hood connections that need to be done.
    I'm also guessing you could have gotten your P3 and wiring harness from them a good amount cheaper than your dealer.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    All good advice above. Your trailer will have electric brakes so you will need a brake controller. With the Tekonsha line of controllers like the Prodigy, you can get the adapter pigtail and the install is plug and play. You might need to install a fuse as mentioned above.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 17, 2025
