lanerd
Jul 19, 2015Explorer II
GraciesDaddy wrote:
Had a Ford Ranger that, once I got it up on the dolly and strapped, removed the drive shaft (recommended), four nuts loosened, drop and slide off the splines of the xmission, DONE! Then bungeed it in the bed of the truck. Takes less than five minutes. I made a "cradle" out of 2-bys bolted to the bed for that purpose. Spend a LOT more time enjoying what's out the windshield than looking at the reverse camera!
But that's just me.
Just a side note on this... often when you remove the drive shaft from the transmission, fluid may run out the end of the trans.
It's better to just remove from the rear end (u-joint) and then raise the drive shaft up and secure it to the bottom of the car making sure the end can't come into contact with the rear end u-joint cradle.
I pulled my Tundra pick up this way for an entire summer. PITA, but it worked just fine and since the truck was 4x4 it was high enough off the ground that it was easy to crawl under to remove/connect the drive shaft.
Ron
PS... on edit, I had a thick rubber band that I would wrap around the cups on the u-joint so that they would not fall off.
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 08, 2025
