GaryS1953's avatar
May 05, 2017
Dometic 2652 quits on propane - NOW WON'T IGNITE
Hi All - Having never camped before without hookups I had never really tried to run our fridge on propane for more than just a few minutes to make sure it worked. It's always been bullet proof on AC. It is only a 2 way, and does not run on DC. Now recently we've been upgrading our battery bank and installing solar and doing other things in preparation for some dry camping this summer and in the fall. As part of that I've been running the fridge on propane to make sure it is working properly for extended periods of time. During these trials the fridge has been lighting normally and get's cold, and works for several hours, anywhere from 12 hours to as much as 3 days, but ultimately the burner will shut down and the check light will come on. If I immediately turn it off and back on it will light normally, but then the cycle repeats and it will go back off after several hours.
It lights immediately and the flame burns nice and clean and blue. Flue is very clean. DC power is good and strong as my batteries are new and my 330 watts of solar is doing a great job of keeping them charged to 12.8 volts. I know there are lot's of threads about theses fridges shutting down after a few seconds to a few minutes, but I really can't find any with this experience where it runs for several hours up to 3 days and then cuts off. Anyone have any experience with this issue and have any suggestions?
Thanks!
