GaryS1953
May 05, 2017Nomad
CavemanCharlie wrote:
Is the fridge getting warm ???? Mine will sometimes not light on the first try. When that happens the Check Light comes on. But, given some time it will try to light again and the light goes off. It will try to cycle 3 times before it shuts down for good.
Are you maybe watching it so close that you just happen to be there during the times when it doesn't light on the first try ??
I watch mine to closely sometimes also. If the red light comes on I start to panic. But, I have learned to give it some time and see if it will relight on the second or third try and then the light goes off.
My fridge has no problem lighting. It comes on and I hear it ignite, and will work beautifully for up to 3 days, with me checking on it periodically, then at some point, several hours to up to 3 days later the check light come on. During the time it's working I've checked it and the fridge temp has gotten as cold and stayed as cold as it normally does when it runs on AC.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 21, 2026
