ronharmless
Jan 25, 2023Explorer
If the fan only can come on when the vent cover is open, then there is a switch in the vent cover. Use a volt meter and check the vent cover switch. You can also jump/bypass the switch to see if it is malfunctioning. You can jump the 0 - 3 switch also to see if it is malfunctioning.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 18, 2026
