Old-Biscuit
Jan 17, 2021Explorer III
Do the dollar bill test (bill between seals/frame door closed and pull it out---should be tight/have resistance
Do it in Several places
Clean seals/frame so you get good clean contact between the two
IF seals are not making good contact you can 'reset' them:
Place cottonball under seal in each corner
Then WARM entire seal using hair-driers (do not overheat but need to get the whole seal warm)
Then close door and let the warm seals cool///resetting them
If seals are good...dollar bill test then it could just be the warm humid air replacing the cool air when you open fridge doors---especially if you lookie-lou
Model of fridge??????????????
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
