jstaffon's avatar
jstaffon
Don't understand my air conditioner
I have a 2016 Forest River Rockwood 5th wheel with a Coleman Mach air conditioner in the kitchen/living area. I've seen intermittent operation that concerns me. The other day we returned from dry camping/boondocking. It was about 90 degrees outside and sunny. When we returned home, we parked the RV in the driveway and hooked it up to 110 vac, 15 amp service using the 50 amp cable and a couple pig tails to get it to the right connector to plug in the outlet. We then turned on the air conditioner to cool things down while we unload and clean the RV. Everything seemed to work fine. We left the air on all night so that as it heated up the next day it would keep the temp around 70. I went out and noticed it was hot out but the RV wasn't cooling. It sounded like it was running but sounded different. The internal temp was around 88 degrees and the outside temp was 92. I turned the air conditioner off and opened windows and ceiling vents to try and get air flow through the camper. We live in a dry climate and air movement and shade really cools things down. Later in the day, I tested the air conditioner and it seems to blow cool air again. The outside temp was 85 degrees and the inside temp eventually reached temps below 70. I've had this happen before. I took it into Camping World to have it checked. They said everything was fine. They told me they look for a temperature differential of about 20 degrees to know if it's working. I can't seem to get it to fail while the mechanic is checking it. Any thoughts on the unusual behavior?
Looking for advice before your next adventure? Look no further.25,182 PostsLatest Activity: Jan 26, 2026
