restlesswind
Oct 31, 2013Explorer
You might check if there is an adjustment possible either on the door or the door frame.It could be that the part on the door frame has loosened and moved
from it's correct placement.
It could be that the lock/latch mechanism need to be replaced.
Check the simple/cheap things first.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Oct 17, 2015
