ianmac23's avatar
ianmac23
Door window leaking
Hello. I have a 2011 Keystone Passport and I noticed this past weekend during a big time rain storm that there was water running down the inside of the door from the bottom of the window. I have watched many YouTube videos on resealing RV windows and it looks like the door window uses a different tape than the other windows. I can not find the tape online.
Thank you for the help
Ian
  • Had it in both mine earlier this summer. Heres my fix
    http://twoguyscamping.blogspot.com/2014/06/water-ever-present-enemy.html
  • IAMICHABOD wrote:
    The design of the door windows make them prone to leak. So the installers most times just seal around them with silicone and hoped for the best,it is a common problem.
    I fixed mine with This solution
    No more leaks, I had a better view and more ventilation.
    IAMICHABOD I have looked at that in the past and it is just not in the budget right now. I just put wet bolts in the suspension. If I spend more on the RV the wife will kill me.
  • The design of the door windows make them prone to leak. So the installers most times just seal around them with silicone and hoped for the best,it is a common problem.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 07, 2025
