- GrandpaDickExplorerThis sounds to me like its going to be a long winter!!
- scbwrExplorer IIYou'll be a lot happier with a Hensley!!!!
- robsouthExplorer IIFagittabout backing that puppy. Go for the pull through sites only.
- craiger4ExplorerNeeds license plate!
- BurbManExplorer III love the open floor plan!
- ceaser_22000ExplorerYou are way over on all your ratings, what kind of tires do you have on that trailer you will need to upgrade to Maxxis M8008.:)
- orlandimalExplorerI see a problem, no lights!
- SuperDutyFiverExplorerIm pretty sure that you'll need a Class A CDL as well-with Doubles, the pivoting front axle will most likely be seen as a dolly at the weigh station... ;)
- shortbus_driverExplorerI will need new tires for sure. I towed it from my garage to the road, blew out 2 tires.
A FRIEND OF MINE WHO IS AN ENGINEER said I wouldn't need a sway bar, it would only make it worse. He also said I wouldn't need antifreeze when I winterized because air doesn't freeze. - EmptypocketsExplorerYou are on the right track - keep working at it and you will get it right. Also it would be a good idea to run it by the weight police.
Looking for advice before your next adventure? Look no further.25,107 PostsLatest Activity: Jan 29, 2025
