- loulou57ExplorerYes I agree newer tires With the tires in the corners it should be stable, will you add a couple of jacks?
How is the wiring set up? - BrucelasExplorerGood thing the trailer is empty, or the weight police would be all over you!
- TucsonJimExplorer IIYou need airbags. What is the GVWR of the TT?
- jmtandemExplorer IIIt looks like it came with a wet bath. Is that what you really want? Also, you obviously need a weight distribution hitch, probably around 1000 pound spring bars, to keep the trailer behind the tow vehicle and not to get into a sway condition. Don't let those on here that might try to tell you that you can tow it on the ball safely and if I were you I would get a one ton dually to tow that beast. Get rid of those junk Chinese tires that it came with. Otherwise, you never know!!!!
