B_s_Bunch
Jul 18, 2013Explorer
How far down the road is this curve from your house. Is this the only curve where this happens. Is your tow bar the kind that has a bar release where you can extend or retract them. Mine has a quick release on each arm. I have noticed on a couple times that one arm did not catch. I usually set the toad brake from the coach to bring the toad back in line with the coach and can feel it lock. If yours is not locked it will indeed travel outside the path of your MH and may very well turn sharper and drag. If any of the above is what you have be sure the bar arms lock. Good luck Larry
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 11, 2026
