David_homen
Aug 08, 2013Explorer
Jagtech wrote:
It might be the non-slip differentials in the Jeep that's causing your grief. I'm thinking that one (or both) diffs are locking up during a long turn, which would make the inner and outer wheels want to turn at the same speed. Try using the factory-recommended friction modifier additive in the diff oil, front and rear, to see if that helps.
Thanks!! I need to get it in for an oil change. I just put some seriously hard miles on it down in Arizona. I will have them check the oil. Thanks Again!!
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
