David_homen
Aug 08, 2013Explorer
Off Pavement wrote:David_homen wrote:
The users manual for the jeep even says to put it in the unlock position after putting the transfer case in N and transmission in P.
My 2013 is the same as your 2014 mechanically, but your manual sure is different than mine. Here is the quote from the 2013 Wrangler owners manual...
RECREATIONAL TOWING (BEHIND MOTORHOME, ETC.)
Towing This Vehicle Behind Another Vehicle
Towing Condition Wheels OFF the Ground Four-Wheel Drive Models
Flat Tow NONE See Instructions
Use the following procedure to prepare your vehicle for
recreational towing...
1. Bring the vehicle to a complete stop.
2. Turn OFF the engine.
3. Press and hold the brake pedal.
4. Shift the automatic transmission into NEUTRAL or
depress the clutch pedal on a manual transmission.
5. Shift the transfer case lever into NEUTRAL (N).
6. Start the engine.
7. Shift the transmission into REVERSE.
8. Release the brake pedal (and clutch pedal on manual
transmissions) for five seconds and ensure that there is
no vehicle movement.
9. Repeat Steps 7 and 8 with automatic transmission in
DRIVE or manual transmission in first gear.
10. Turn OFF the engine.
11. Firmly apply the parking brake.
12. Shift the transmission into PARK or place manual
transmission in gear (NOT in Neutral).
CAUTION!
Damage to the transmission may occur if the transmission
is shifted into PARK with the transfer case in
NEUTRAL (N) and the engine running. With the
transfer case in NEUTRAL (N) ensure that the engine
is OFF before shifting the transmission into PARK.
13. Attach the vehicle to the tow vehicle using a suitable
tow bar.
14. Release the parking brake.
We pull the key and lock the doors when we tow our '13.
I misspoke. It is a 2013 and I have my manual setting here beside me. I am going to find the Jeep and RV recommendations for towing. Every Dealer and RV Dealership I have ever come in contact with Stresses that the steering wheel be unlocked.
Anyone else leave turn your jeep, pull the keys out and tow?
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
