bshpilot
Jul 20, 2014Explorer
David_homen wrote:
It is a Falcon II tow bar, the jeep is a 2014 Rubicon 4 door. I am very sure the wheels aren't locked. The new Jeeps don't like to have the battery disconnected so when I put the key in the unlock position everything is on. I even tried to disengage the traction control. No Joy .........
after 2010 there is no steering lock - so no need to keep a key in the ignition or turned on. I tow ours w/out a key or ignition turned on.
my 2012 still has an ignition relay that is designed to be pulled (as a method for disconnecting the ignition w/out killing all the program info / radio etc)....but again that is NOT necessary since the key is lot left in the ignition or on during towing.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
