PatrickFisherPr's avatar
Dec 19, 2015
Drawing more than 12 volts off auxiliary battery
I have a 1984 Toyota Sunrader. Under the hood is an auxiliary battery, which charges off the alternator. The auxiliary battery operates my water pump and the furnace.
The furnace requires approximately 13 volts to open the gas valve and spark the ignition. It appears I only get the proper voltage to start the furnace when I turn over the engine.
Any thoughts on how I can draw more power from the auxiliary engine without having the vehicle's engine on? The furnace kicks off if the RV reaches the temperature to which my thermostat is set. If the RV reaches that temperature and the engine isn't running then it doesn't have enough power to reignite the ignition if temperatures drop.
Any insight would be very appreciated.
  • What furnace brand/model do you have?
    Most RV furnaces have a DC operating 'range'
    Transformer increases DC voltage to 10K for spark ignitor
  • RoyB's avatar
    RoyB
    Explorer II
    A fully charged battery only produces 12.6-7 VDC
    Never hear of deal where you had something in a 12VDC vehicle setup that had to have 13VDC to work...
    Only way you can get more DC voltage is using your alternator which will be producing 13.2 to 13.6 in normal mode and may jump up to 14.4-4VDC when in charge mode...
    If you valve doesn't draw much DC current then maybe install another 6VDC battery in series with the 12V dc outputs and set it back to 13VDC with a resistor...
    Maybe you need a newer toy haha...
    Roy Ken
