dbates
Sep 26, 2015Explorer
Glad you got there safely!
I and may others on this forum have found that "Big Katuna's suggestion about the front wheels "snug against the front stops" is not the right thing to do. When this is done the straps will not slide over the tires and leaves some slack behind the tires. It's been proven that if you leave about 1/2 to 1 inch clearance between the tires and the front stop, as you tighten the straps down the wheels will roll forward making the tension equal in both the front and back of the tire, plus make sure that you tighten the straps down until the tires squish. When this is done I've never had to tighten a strap since I started doing this but I still check the tension whenever I stop.
When you park always remember to leave the dolly tires away from a curb or you'll scrap the lettering of the curb tire and always leave plenty of room in front to pull out because if you pull out to quickly the dolly tongue will swing toward the curb and force the tire into or over the curb.
Dave
Dave
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 24, 2026
