Lynnmor
Jul 09, 2018Explorer II
You should not replace brake shoes that were not worn or defective. New shoes will have much reduced braking power for a long time till they are "burnished." Burnishing is a word that the manufacturer uses and is a bit misleading, actually there will be a film built up on the surface of the shoes and drums. Turning up the controller will accelerate the process at the expense of increased magnet wear and possible grooving of the armature. You should test for a wiring fault if the braking has decreased with no other changes.
Self adjusting will work on forward braking, but be aware that the adjustment will not be correct if the drum has too much run out.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 17, 2026
