The generic formula to figure is
GCWR >= GVW + Trailer + stuff
....actual weights and includes people, pets, etc, etc, etc
Why said, if you don’t have actual weights...use the max rated limits, but know still guessing until you actually weigh it axe by axle
This comes up often, so copied an old thread and not retype...
Help me make sense of my vehicle's towing capabilitiesBenK wrote:
Welcome to the forum !
You will need some basic information and a few trips to the scales
Basic info needed:- GCWR
- GAWR, front
- GAWR, rear
- Actual TV weight by axle
- Actual trailer weight (if you don't have that yet, use it's GVWR as that is that is heaviest weight it is rated for
- Actual tongue weight (if you don't have the trailer, use the brochure tongue weight and calculate the tongue percentage weight vs the listed 'dry weight'
Then the simple math using the above data
Normally suggest newbies first decide if they believe in their TV OEM's ratings system (even generic OEM Ratings system) or not. If so, then do the above...if not then academic this and just do whatever...but your comment says, I think, you do believe
Also, assume you used to just hook up and go 'cuz of owning one of the highest class pickups...and now you want to/need to figure it out to not wear out or kill your new TV
Comments embedded in red below
dante93gtz wrote:
I'm trying to best determine what my truck is (and is not) capable of hauling. We recently sold our F350 diesel in favor of something with 3 rows of seating. We bought a '14 Cadillac Escalade ESV AWD. That being said, I'm coming from the world of being able to tow most anything to now having to think about weights and capacities again. :(
The Mrs. and I have started talking about a camper to get our young family out in the woods more easily than by tent camping. In an effort to make the most informed decision possible, I wanted to get some opinions from the forum.
I've done some preliminary research on my vehicle but based on the results, I'm concerned that either (a) I've not taken a variable into consideration, or (b) my new TV is much less capable than I originally thought.
Alright, so... I've got the basic figures listed here along with what I believe are accurate weights:
'14 Escalade ESV Weights w/ Class III hitch (in lbs.)
Curb Weight: 5982
This the basis from which most all TV OEM's derive the tow ratings....but note that this is the 'stripper' model with ZERO options...other than the 'Tow Option' and one 150 lb driver. Most times, the OEM does not offer a 'curb weight' (stripper) model for sale.
As noted by others...an Escalade is in the top tier of bling. All of those options add weight...which deducts from the MTWR (Max Tow Weight Rating) pound for pound
Then the additional stuff. Like people, pets, cargo in/on the TV,
after market stuff, etc, etc...all deduct, pound for pound, from the MTWR
My 3/4 Ton Suburban, K3500, 7.4L big block and full up option packages weighs in around 7,200 lbs with just me in it (180 lbs)
SMOG test has the official DMV form list my curb at 5,250. Wonder how much stuff would need to be unbolted and tossed to get it down to 5,250...
The big block and bigger automatic might be about 300-400 lbs more than the small block and smaller tranny..
GVWR: 7400
A half ton and worlds different from your 1 ton
Biggest difference is in the rear GAWR and is where most half tons in the lower class get into ratings trouble
Carrying Capacity incl. tongue weight: 1418
Theoretical Passenger Weight: 500 (2 adults, 3 small children + small carry-on items)
Theoretical Fuel Weight (31gal): 196
Theoretical capacity (of GVWR) for tongue
weight afer fuel and passengers: 672
The only way to know is to use the actual tongue weight. Hope your new trailer is light weight
Towing Capacity: 7700
Again, this MTWR is derived from a 'curb weight' (stripper) model
Unless your TV is a stripper, it will weigh hundreds to a thousand pounds more and that will reduce the brochure MTWR pound for pound
Weight of the camper itself aside, by my figures it looks like I should be looking for a travel trailer with a tongue weight of <672lbs, correct? That seems fairly low, considering the trailers we've been looking at are generally 700-800lbs for the tongue weight. Of course, we'll be running a WD setup but I know that doesn't reduce tongue weight.
Any advice or input based on these figures? We still have access to my father's Dodge 3500 is we *had* to use it to go camping, but we were really hoping to use the Escalade since the kids will be much less cramped inside. We don't plan on going much further than 200 miles away from home as we live very close to many of the areas we'd like to camp at.
Thanks in advance,
Brian
