ChristyFord's avatar
ChristyFord
"Dry Weight" Questions
If "dealer installed options" are not counted in the dry weight of a travel trailer, is there a rule of thumb estimate to include when calculating potential GVW? And what would constitute those options? I can't see why the a/c unit and fridge would be "options," why would those ever be left out of a trailer, but what do I know.
Also, when looking at specs I see "hitch weight" listed, is that a separate weight or is that included in the dry weight? Or is that meaning what the tongue weight would be if you towed it as-is?
https://www.rvusa.com/rv-guide/2017-forest-river-grey-wolf-toy-hauler-floorplan-19rr-tr32338
  • Mortimer Brewster wrote:
    I think a lot of dealers list or emphasize the dry weight in order to fool the customer into thinking their tow vehicle is capable of towing that trailer. As others have said, go with the GVWR.
    x2
    All dry weights are a joke and the joke is on you if you believe them. Only a salesman trying to get you into too much trailer will ever quote them. Go with the GVWR and you will probably be safely under that number.
    :C
  • I think a lot of dealers list or emphasize the dry weight in order to fool the customer into thinking their tow vehicle is capable of towing that trailer. As others have said, go with the GVWR.
  • Wish I could help you but my recent experience is that the published weight, the delivered weight and the yellow sticker (which is off by 1000#) have no basis in reality.
    I would simply go by the GVWR of the new trailer and make sure your rig is rated for that number.
  • Listed/published 'tongue/pin weight' is 'DRY' weight based on the 'Listed/published' DRY trailer weight.
    (500# dry tongue for 5000# trailer equals a DRY 10% tongue weight etc)
    Dry tongue/pin weight is for a basically empty trailer.....(lot of mfg. fine print will state 'Numbers are an Average' for such & such model
    Look at data plate on trailer for the GVWR.
    Use the dry tongue/pin weight percentage to figure WET tongue/pin weight based on GVWR
    Can your TV handle that WET tongue/pin weight?
    If so........good to go
    IF 'marginal' might be OK if you do NOT load trailer up
  • ktmrfs wrote:
    for trailers built in the last 10 years, the yellow sticker on the trailer lists the weight as it LEFT the factory, so ALL factory installed accy are included.
    what is NOT included is anything added by the dealer.
    and in MOST cases the dry weight does NOT include batteries since they are usually dealer installed. it does include the weigh of full propane tanks.
    Not necessarily ... with my own 2014 Freedom Express the weight of propane gas that would eventually be added to the tanks by the dealer is not included in the trailer's listed UVW, on current models it is.
  • If your TV is rated to tow the TT's maximum recommended weight plus 20 per cent, you will be fine.
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    Now hitch weight is again hitch weight as it left the factory it does NOT include a few items that translate almost directly to added hitch weight
    1) battery(s) figure 70 lbs each
    2) propane, figure 20 or 30 lbs each accordingly.
    and all the stuff YOU add to the trailer that adds tongue weight.
    For an example, my outback has a claimed and actually dry tongue weight it the mid 700's, I don't recall directly, but my measurements pretty much matched the factory claim.
    ACTUAL tongue weight with propane and my 4 GC batteries full fresh water and trailer loaded as we travel....... 1450 lbs!!!!
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Dec 22, 2025
