chipster's avatar
chipster
Dual cam VS Equalizer...I have both
So here is my humble Opinion. I just picked up a TH that came with a the four point equalizer hitch(1200# bars)so I just used that to tow home over 300 miles and it towed great, mind you that was and empty trailer no water or camping gear or fuel. So I had already pre purchased a Trunion 1700# bars dual cam set up as I had dual cam before and wanted it ready so once we found a trailer I would be good to go to go pick it up. Theoretically it should work better.
So here are my observations.
The equalizer hitch bars make contact on the full surface area that is used to create the friction which is about 2"X 2" plus where the bars lock into on the head add additional friction or sway control and absolutely no play. everything is tight and easy to hook up.
Dual cam, uses the cam method to stop sway by applying more force when the trailer tries to push the bars out of the locked in cam position. Only problem I see is this cam fitment is very very poor. Look at your wear marks on the bars and the cams themselves and you will be lucky if more than a third of the surface area has any wear marks. Thus not providing near as much friction or metal on metal area the equalizer does. Also the trunion style bars have so much play in them at the connection point on the head. Sure under weight will they move not likely but they can where the equalizer has no play thus to me providing an overall better hook up.
My tongue weight is 1650# so I am inclined to keep using the Dual cam but if I had the 1400# setup for the Equalizer I think I would go that route.
Plus the Equalizer is so much easier to set up, trying to get the cams seated 100% takes some time, and also if the TV and Trailer and not loaded exactly every-time it could change the geometry of cam position not seating 100%. Equalizer flat surface, no worries.
Just my thoughts since I was able to compare both on the same trailer, not many have both units kicking around.
I am thinking of bringing along the Equalizer and might try swapping it while on the road to compare the difference. Take all but maybe 30 mins. to swap over, just need to check to make sure dual cam brackets on trailer are not in the way. L brackets for Equalizer bolt on in minutes.
  • Not sure if the load in the TV would really change the DC setup but what I do just in case is before I hook up to the TT I use the airbags I installed on the truck to return the TT to the height it was at when I setup the DC. Also, IMO its not the size of the friction area that makes the DC effective but instead its the bars pushing the A-frame back into a straight line.
  • Give the DC some miles and the bars will seat themselves to the cams. mine have 100% contact! and I`m sorry to say that there is no sway control effect from the attachment points at the hitch head. it would take quite a bit of side to side trailer movement for those 2 points to help out that it would be to late!
    I`ll go with the DC every time!
  • I love the EQ 4pt system. It is very quick to hitch & unhitch.
    However, the biggest draw back with that system is a complete new system is needed when stepping up in each weight class.
    By the way, I don't think you want to go over the spring bar weight on the Equal-i-zer.
Looking for advice before your next adventure? Look no further.25,157 PostsLatest Activity: Aug 20, 2025
