afinepoint
Jun 14, 2013Explorer
George H wrote:
First thought is air pressure. Assume you have 235x85 16 load E, max pressure s/b 80lbs try that and see if it helps.
Yes, 235/85 R16 load range E. The tires were set around 75 psig when I left Pep Boys. Towing yesterday I set them at 70 due to heatup. I didn't think it would affect things significantly. I've had the Kumhos at 80 and well below and never felt the floating sensation.
I normally always set all tires to 80 psig cold. Was curious how the truck would pull with a lower pressure and was concerned about the blowout. I'll set all to 80 when I pick up the trailer in two weeks.
FYI the trucks outer rear tires have always lost pressure faster than the inner. I can set all to 80 psig let the truck sit and check it weeks later and the outer will be in the 50's or less while the inner are still within a pound or so of 80. The front will also be fine. A dually mystery.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
