jdonnell's avatar
jdonnell
Dumping black tank - for stationary travel trailer
Just wondering if anyone out there has this same situation, and what kind of solutions are available.
My TT is parked on our mountain property. It is mostly stationary, but we do take it out once in a while. We use it a lot on the mountain property. I am trying to find different ideas / solutions for emptying the black tank.
I have a portable tank (27 Gal), in which I dump the black tank, after every trip. After 2 trips (sometimes 3), we have to empty the portable. In which case, I have to load it into the back of the pickup, drive to the nearest campground (1.5hrs driving time) to empty the tank. While this has worked for a few years now, I am trying to find another solution (if any are available). So, I would like to find out if anyone else has a similar situation, and what they do.
I can not install a septic system on the property at this time (county says the house permit must be in place, before a septic can be installed... and there are no house plans at this time).
Anyone have any ideas ?
Thanks
  • Yes put a small pool on your property without alerting the town, keep the access covered with leaves if the town comes over, no way would I be driving 1.5 hrs....to dump.
  • Sounds like your best bet would be a macerator. I'd bet you're leaving a lot of 'stuff' in the black tank since you're not flushing it with lots of water. With the macerator, you should be able to put your tote in the back of the truck when empty, then dump.
