IDoMyOwnStunts's avatar
May 09, 2016
Dumping fresh water
I'd like to hear some opinions and considerations on dumping your freshwater tank. Where do you do it? Do you go to a dump station and let it run into the drain? Do you pull the valve open at home and let it run in the street or on your pad? What about at a campsite? Do you pull the valve and drive? And finally, do you do it differently if you have bleach or other sanitizing agent in it vs when you are just winterizing or shedding weight for towing?
I've seen people pull the valve and drive, but I'm not sure how others feel about that. I personally pulled the valve at home, but I have no RV pad, so it runs in the street. I'm on a hill, so it doesn't completely drain at home. But if I need to sanitize, I really wouldn't feel too comfortable about dumping bleach water on my street because the drain runs into a creek about 4 houses down. Thanks.
To be clear, I am talking freshwater, not grey. I have a 100 gallon tank.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
