Our_Place's avatar
Our_Place
Duramax and towing a 10600lb 5th wheel
This is a question about the trans. Should I just leave the truck in "D" and go or should I be in manual mode and restrict it to 5th gear? The truck seems to be laboring on slight uphill grades but will pull no problem if you mash it to get it to downshift. The truck is a 2008 with the 6 speed Allison.
  • My Allison doesn't have a tow haul mode so I will drop it down gear by gear depending on how steep and long the grade is. I pull a 15000 lb 5th wheel and on 6% grades I'm often in second gear under 30MPH with the go pedal pushed to the floor. This seems to be a good place for the engine/trans, very smooth, no lugging and temps don't climb up.
  • kaydeejay wrote:
    Leave it in "D" and select "Tow-Haul".
    Your computer is smart enough to figure out the best gear to be in.
    Yep, I agree too. Leave it in D.
    The only time I need to shift up or down is going down or up steep grades but even then it's rare I need to fiddle with anything.
  • Leave it in "D" and select "Tow-Haul".
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Mar 04, 2025
