JaxDad
May 05, 2014Explorer III
mpierce wrote:
The ethanol is 10% less energy per gallon than gas. There is a 10% mix. So, 10% of 10% means there is 1% less energy per gallon.
I think your numbers are a little off. Gasoline contains ~114,100 BTU's per gallon. Ethanol contains ~76,100 BTU's per gallon.
That means Ethanol contains 66.67% of the energy of gasoline, not 90% less.
In the case of E15 then you would be losing ~15% of the energy per gallon.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 27, 2026
