dodge_guy
May 05, 2014Explorer II
mpierce wrote:dodge guy wrote:
The energy in fuel with 10% E is way less. Enough that my X could barely hold 55mph in a headwind. When i switched to 93 octane my power and mileage came back. When i fill up in WI with real gas my X runs like it was supposed to.
The ethanol is 10% less energy per gallon than gas. There is a 10% mix. So, 10% of 10% means there is 1% less energy per gallon.
If the engine is adjusted to compensate, which all in the last 20 years or so are, the power will be the same. You could burn 1% more fuel to do it.
So, if you had been getting 25 mpg with straight gasoline, you could drop to 24.75 mpg. I defy you to be able to tell that.
I have been running it since the 80's in all my engines on the farm, and there are a LOT of them, including small ones. I have not had ONE SINGLE PROBLEM.
Not sure in your numbers either, but i can tell you that i can see the difference in my mileage and can definitely feel it power wise. Ethanol fuel is good for the corn growers and bad for motorists!
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 27, 2026
