Jarlaxle
May 18, 2014Explorer II
ol Bombero-JC wrote:Kurbennett wrote:
Ethanol has wrecked havoc with a lot of small engines. 10% blend has been seen to ruin gas tanks and engines on many motorcycles. Most motorcycle manufacturers recommend not using ethanol laden gas at all. Luckily non-ethanol gas stations do exist. Of course it does cost more, but you also see better mpg out of it.
Now as far as use of ethanol gas in RV's and possible consequences I have not seen any. I would not use a 15% blend though. As for rationing and shortages, the current higher costs of gas seem to be from our exporting of oil to other countries, versus a shortage.
Mostly incorrect!
UN-luckily, NON-ethanol gas stations are *VERY* few and *VERY* far between in some states..:(
In the most populous state in the USA (CA) you can count 'em on one hand - for the entire state..:(
UN-fortunately, ethanol is bad news for any gasoline powered engine, especially any engine that is not run frequently..:(
Motorcycles are just one example - RVers: think "generators"!
Antique autos are another.
Old ethanol gas *WILL* clog carb jets..:(
Be sure to add SeaFoam or StaBil to the tanks of *any* gasoline powered engine that is not run often.
Well, YEAH! If storing an engine, I have ALWAYS used stabilizer!
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 27, 2026
