LarryDel's avatar
LarryDel
Explorer II
Aug 03, 2019
Electric cooler off of 12 volts
Just purchased Coleman Electric cooler. It runs on 12 volts or 120 with adapter. We have class C motorhome and in a seasonal campground with electric hookup. We would prefer to plug cooler into 12 volt source permanently because there is not a nearby 120 outlet. Will this cause any problems such as running batteries down or over using 12 volt outlet. Thanks much!
  • Those are great for supplementing a fridge when you are out of space and ONLY when you have 120 household current. Also fine for driving while engine is running.
    I assume you mean a cooler like a Coleman???
    TERRIBLE to run off a battery.
    These are not like the high-end Danfoss compressor fridges that only sip electricity. These are power hogs and will kill batteries fast. Batteries are expensive. If you run it off your battery you will soon learn the true cost of a cheap "cooler" is that batteries cost over $100 each and will not last long.
    Is it too late to return it?
    For $600-800 you can get a chest refrigerator that has a Danfoss compressor (or similar) that will be much more kind to your batteries. Yes, it sounds like a whole-lotta money, but in the end, if you camp a lot, it is a great value and will last a long time.
    ***edit, The Danfoss compressors run for a very small percentage of the time it is plugged in, where the Coleman cooling unit runs 100% of the time. Power draw in amps might be similar, but the time running those amps is not, thus the difference in power consumption. In cooling there is no comparison, the compressor ones are better.
    ***If you like big-boy toys, then these are cool things to have….
    If you are waiting for SHTF then these are a valuable thing to have around if power goes out. The recent NY power outage was talked about as a china hack. Maybe, maybe not, not my problem, but power does go out in storms, or disasters. Ability to keep food… priceless
  • You will flatten your batteries rather quickly. Not a good idea without the needed 120V to keep things going.
    I have one of those coolers I used to use a lot. Forgot to unplug it late one night. Next morning my dual battery truck wouldn't start.
    As long as you are plugged in to shore power it will work.
Looking for advice before your next adventure? Look no further.25,158 PostsLatest Activity: Jul 30, 2025
