F350_RR
Mar 24, 2018Explorer
myredracer wrote:
Remote thermostats also normally have a heat anticipator so you can adjust the on/off cycling time and built-in ones don't have that feature .
The Atwood hydro flame furnace thermostat has an anticipator. The on-off switch needs a small hammer to operate however. Weather is almost warm and dry enough to take the TC cover off and install the Honeywell stat next to the bed. I plan wiring in parallel so I can use either.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
