wa8yxm
Jan 11, 2014Explorer III
RangerJay wrote:
We played with ceramic heaters, tower heaters, radiant heaters and oil-filled radiators ad nauseam for several years before finally installing two 120V baseboard heaters and a digital wall-mount thermostat that has very narrow and precise temperature control (+/- .15 degrees C) - the difference in comfort is night and day - there are no longer "cold" times or "hot" times
I suspect.. That Thermostat is the reason for the comfort.
I use small "Cube" type heaters here both Ceramic and "other" but... The problem I have with them is the thermostat.. I'd love to use a digital wall mount on most of them. and that .15C (Wow, that's less than 0.1 F) would make it the same temp +/- basically nothing all the time.. Now that is what makes for comfort.
Can you please post or PM me the make and model of that T-Stat.. Thanks
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 16, 2026
