pianotuna
Mar 13, 2017Nomad III
My first choice is radiant heaters, however, those need to be carefully placed. My next choice is oil filled which are about the safest of all the electric heaters. I love my electric heated carpets.
If I were to start over, I'd get baseboard heaters and run them along outside walls.
I do heat 100% electrically if I have a sufficient power supply. To the OEM 30 amp shore power, I've added 20 amp and 15 amp. I have run up to 7000 watts.
I chose to replace the return air grill on the furnace with dual window fans--that solved water freeze up problems and pushes a small amount of air through the ducts.
I've camped at -37 c (-34 f).
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
