DrewE
Mar 13, 2017Explorer III
Yes to electric heaters. Others have covered most of the details quite well. I use an inexpensive basic heater from time to time, both for warming and as a load for exercising the generator in seasons when running the air conditioner as a load is inappropriate or impossible.
Do check that the plug isn't getting warm after a minute or so of operation. Some RV outlets tend to make rather poor connections with the plug or with the AC wiring, and heavy loads (like an electric heater) will cause poor connections to heat up...sometimes dangerously. From that point of view, having two heaters on low would be preferable to one on high, even though the heat output is usually about the same.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
