time2roll
Mar 13, 2017Nomad
ricks99 wrote:First check the operation of the propane furnace. Especially the ducting needs to be open and clear moving lots of hot air. If the furnace burner cycles while it is in the heating mode then you have poor air flow.
Our HTT has propane heat, but when it is cold (as it was this past weekend), it can run A LOT.
Otherwise I use a 1200 watt radiator style heater to supplement the furnace when temperatures are expected to approach freezing or below.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
