ricks99
Mar 13, 2017Explorer
Electric heating options when on shore power?
NOOB heating question...
What are the electric heating options when on shore power? Our HTT has propane heat, but when it is cold (as it was this past weekend), it can run A LOT. Seems like an easy way to burn through the tanks rather quickly. I did remember to switch to the electric water heater at least!
Do y'all use small electric space heaters? Is that preferable to running the onboard gas heater all the time? I assume that if I'm on full 30amp shore power, the draw from the heater(s) should be OK?
TIA
TIA
