Lottie's avatar
Lottie
Electric lift on pop up
Hello all. Hope this is the appropriate forum for my post. I recently bought a 2005 Rockwood Freedom Model 2270 pop up. It came with a factory installed electric lift which I was looking so forward to. At first it seemed the battery that powers the lift was shot but then we thought it was the electric motor on the lift. I take the camper to the RV repair shop and in the end they put a new battery on it and say it's fine. I get home with it and can tell right off that the lift isn't working right, it would get it up about 1/3 of the way and quit then after waiting about 5 minutes you could get it to inch up a bit more. I decided to shut it while I had the opportunity and the closing part was quick.
My question is this: where can I buy an electric motor for the lift? Also is there an option for a manual lift on this trailer, like in an emergency? I appreciate your help.
  • Our starcraft, years ago, had a hand pump right at the electric pump right under the counter It worked but really slow going.
  • There should be a manual crank, or at least a hex or square for jacking. Once you find it, take a cordless drill and try to raise the top.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: May 03, 2023
