mooky stinks wrote:
JIMNLIN wrote:
The trailer shows a 7495 GVWR = 1875 lbs per tire....
Dry weight says around 6265 = 1560 lbs per tire....
This = around 1200 lbs of CCC so most likely the trailer will weigh close to its 7495 lb max gvwr.
The Endurance ST 205/75-15 load D at 65 psi and a 2175 lb load capacity will give the trailer a nice 15% load reserve capacity. ?
Some tire dealers have excellent experience with trailer wheels tech and tires tech (matching pressures/load capacities/proper width/etc).......others ??.
For this trailer I would stick with the OEM sizes/load ranges.
edit ....jim
Are you forgetting tongue weight deducts from axle weight? The 7500 GVW would be closer to 6500 on the axles.
Good point.....which makes the 205/75 tires even a better choice for this size trailers wheel load needs.
Another good option for replacing a ST205/75-15 C or D tire.......I've ran several tandem axle cargo trailers as worksite tool trailers. Some came with the ST205/75-15 tires. These trailers ran lots of miles per year using up to two sets per year.
I gave the ST tires to my other drivers/employees for their utility trailers/boat trailers and had my truck tire dealer mount LT215/75-15 D load range at 2095 lbs capacity or LT 235/75-15 C load range at 1980 lb capacity.
These tires had enough tread depth to run in the 50k-55k miles of service before tread wear bars came close.
