joelc's avatar
joelc
Nomad
Dec 10, 2013
Engine light and Wrench code 2006 F-350 Diesel
We are full timers and when we were towing our 5th wheel in September to a campground in N.C. my truck engine light went on and I lost power going up a hill. I was able to pull over and shut the truck down and restarted it and had no more issues. Later, my wrench light went on but the truck preformed normally. I did reset it once while overnight camping and after restarting the truck the light went on a second time. I drove to N.C. without resetting again and after I brought the truck to a Ford dealership, they got the code and traced the probable cause to a bad alternator. I have driven the truck without the 5er and the code has not returned. The truck has not been used often, and I have let the battery run down a bit. After starting I check the output to the batteries and they seem to be charging fine.
The truck is a 2006 F-350 diesel dually CC with a long bed.
Any suggestions?
