Old-Biscuit
Dec 23, 2013Explorer III
Runaway Train wrote:
I have a Monaco 40 ft diesel pusher with a Cummins ISL 400hp Turbo Diesel Engine. The temp guage range is 100 to 250 degrees. At 55 to 65 road speed on relatively flat terrain (South Alabama/North Florida) the temperature tends to run around 240 degrees. Is this normal?
Thanks for the response. Just to add. My temp gauge and the monitor both show the same temp within a couple degrees. If the sending unit was bad would I still see the same information from both sources?
What does the temp do under different conditions......climbing hills, slow speed at a crawl, stop and go traffic?
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
